跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Shot or lost AM/FM Functionality
Hello world. I am putting this out there. My family has a 2006 Dodge Caravan, and it was functioning until over 1 or 2 years ago when it stopped subsequently Receiving music from my families favorite stations, and the Cassette Deck along with the Disk Slot stopped receiving ANY power, whereas before the darn thing became shot, the AM/FM Function would stop and start. The clock still works, but so far that’s all. Is it an issue with a fuse, or is it something internal such as the Caps? Please respond because I want music again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @therepair
There are 3 fuses associated with the audio system #5, 14 & 20, so you may want to check all of them to make sure that they’re all OK. The clock uses a different fuse so that is why it still works.
2 of the fuses i.e. 14 & 20 feed directly to the radio and the amplifier respectively, but fuse #5 feeds through the accessory relay which is operated by the ignition key. If your front cigarette lighter is working OK then fuse #5 is also OK
Here’s a composite image of the power supplies to the radio unit taken from the 2006 Dodge Caravan service manual that may help. It shows how the power gets to the radio and amplifier. If the fuses are all OK, check that power is getting to the connector pins on the radio and amplifier as marked on the wiring diagram and if it is there OK then the problem is in the radio (or amplifier)
(click on image to enlarge)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cole Lindemulder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 281
