Am I calibrating my new laptop battery correctly?
So I recently got a new laptop battery from iFixit (an aftermarket battery, since the OEM ones were out of stock) and was able to replace it.
I charged the laptop to 100% & left it plugged in overnight, and then when I was draining the battery, my laptop ended up completely shutting off with no warning when my battery showed 40%. Plugged it in, turned it back on, the battery percent showed 1%, so I charged it back to 100% again -- I actually witnessed the battery percentage jump from 60% to 100% during this charge. This time around (2nd discharge, my laptop died again, no warning whatsoever, at 30%, and now I'm charging up again for a 3rd time.
Is this normal? I don't even get any low battery warnings before the sudden shutdowns, but at the same time, the battery time I'm getting off this battery is WAY longer than with my old battery even with the random shutdowns. Should I be worried, or are these random shutdowns part of the calibration process? If they are normal, how much longer will it take for my battery to start acting "normal" (like going into battery saver mode at 20%, then warnings at 10% and 5% before dying)
