跳转到主内容
加入维修社区 - 创建账户
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Necessary Components for Screen Replacement
Hi,
I’m confused about which components I need to replace my iPad 6th Gen screen.
I think I have it right but I’m not sure. I have in my cart the following:
***iPad Air, iPad 5, iPad 6 Adhesive Strips***
***iPad 5/6/Air 2/mini 4 Home Button Gasket***
***iPad 5/6 LCD***
***iPad 6 Screen Digitizer***
I already have the Essential Electronics Toolkit, which I think is up to the task.
Many thanks in advance
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the first generation iPad Air, iPad 5, iPad 6 model A1474, A1475, A1822, A1823, A1893, A1954 tablet.图片
产品
$6.99
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair.图片
产品
$29.95
Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4.图片
产品
$1.99
Replace a LCD Panel compatible with the iPad 5 A1822 and A1823 and the iPad 6 A1893 and A1954 model tablets. 9.7 inch LED-backlit 2048-by-1536 resolution at 264 pixels per inch (ppi).图片
产品
iPad 5/6 LCD
$79.99
Replace a scratched or cracked glass digitizer touch screen on an iPad 6. This part is only the front glass. The LCD is not included.图片
产品
$49.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @rogercorbett,
Take a look at the guide to replace the front panel assembly and check out the Parts and Tools sections to see what you'll need. (Steps 1-40 will instruct you on how to remove the LCD and when you keep following you'll remove the digitizer, as well.)
As far as I can tell you seem pretty set with that list! My only suggestion to add would be an iOpener to help soften the current adhesives and a battery blocker (or you can make one using a playing card!)
Good luck with your repair!
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.图片
产品
iOpener
$24.99
The battery blocker allows the battery in many devices to be disconnected without removing the logic board.图片
产品
Battery Blocker
$3.99
iPad 6 Wi-Fi Front Panel Assembly图片
指南
iPad 6 Wi-Fi Front Panel Assembly Replacement
难度:
困难
55 minutes - 2 hours
iPad图片
指南
How to Disconnect an iPad Battery with a Playing Card
难度:
简单
5 - 10 minutes
这个答案有帮助吗?
得分 1
1条评论:
Hi @amber thank you very for your advice. It’s all adding up so I think I’ll get the battery blocker and make do with a hair dryer.
完成的
添加一条评论
添加你的答案
Roger Corbett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 527
