跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Headphone broke inside headphone jack.
Hey everyone, My macbook air has had a piece of my headphone stuck in it for 2 weeks now. I first tried to get it out with tweezers and pliers, which pushed it in further.
I tried the pen tube with super glue, then a q-tip with a hole groove filled with super glue and it didn’t work. It stuck to the piece of the headphone but never pulled the piece out, which left a residue now even harder to retrieve due to the residue. I tried a push pin bent into a hook, and it didn’t do anything either.
Now, my final question before having to take it into Mac Medics…I saw this video
https://www.youtube.com/watch?v=YdFZGMqO...
if I get that Pentalobe screwdriver and take the back of the Macbook Air off, will I be able to get to the headphone jack area to force the broken piece out?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well that vid won’t help you, instead follow this guide MacBook Air 13" Mid 2012 I/O Board Replacement to get the I/O board out which is where the headphone jack is located.
You could try pushing the stuck part out by carefully drilling a small hole in the back side to feed a small paperclip wire into it. Or, just replace it as the glue may have damaged it MacBook Air 13" (Mid 2012) I/O Board
MacBook Air 13" (Mid 2012) I/O Board图片
产品
$89.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Keegan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 30
