跳转到主内容
How to Change out charging port
My son damaged his charger and then jammed it into the charging port damaging it. Now I need to replace it and feel comfortable doing so based instructions online for similar devices but I want to make sure to order the correct replacement part. Can anyone help? The device is a Lenovo Chromebook C340-11
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
Here’s the hardware maintenance manual for the laptop.
Go to p.31 to view the necessary pre-requisite steps and then the procedure to remove/replace the I/O board (supplier example only).
Search online for 5C50S24976 to get results for suppliers that suit you best.
这个答案有帮助吗?
得分 3
1条评论:
This was so helpful, thank you so much!! I was able to remove the I/O board and I got a replacement ordered and on the way!
完成的
添加一条评论
添加你的答案
Brooke Gullett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 278
