跳转到主内容
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
20 个问题 查看全部
I replaced the screen but it will not turn on
I replaced the screen on my watch, but the screen remains black and I don’t think the watch is turning on at all. I do not feel any haptics or anything like that. I don’t think the battery is damaged, but I suppose it is a possibility. The watch was smashed until the screen fell off. When that happened the watch was still turned on and I just let it die.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
hello christian,
put a watch on charger and check (try switch off, you ‘ll feel vibes). Often, during replacement, the connecting tapes are damaged or one of the connectors does not click properly. In such cases, you have to disassemble everything again and try from the beginning. Unfortunately, lately many of the new (replacement) screens for Apple watches are simply not working. Find a good repair shop, let them worry there.
这个答案有帮助吗?
得分 1
2条评论:
I tried putting It on a charger and nothing happens still. And with the screen m, I bought an OEM screen and nothing about it looks like it wouldn’t work. What did you mean by disassembling everything and all that?
完成的
Is it possible that the battery is the culprit?
完成的
添加一条评论
Try removing the battery, and do a reset.
Then reattach the battery.
I've had many play up like this, then out if the blue, they'll fire back up when put on charge.
Sometimes the flex cable can be damaged.
Also, you say you've replaced the display? If so, are you aware the NFC part need to be swapped over to the new display, as they're paired with watch.
这个答案有帮助吗?
得分 1
4条评论:
I’ve tried that and it still doesn’t work, but I’m not aware of that, how would I swap that over?
完成的
On the back of the display, there's a large sheilded chip. That's attached to a thin flex like strip that runs down to the LCD flex fold.
Heat & isopropyl to removed the full assembly, then transfer over to the new screen.
But first, you want to get the watch working, because if you damage it, you'll be running around in circles trying to find faults.
Assuming no other watch available to test the display on?
完成的
That is correct. Unfortunately though, I don’t even have the old display to transfer anything over. So I’m pretty sure I’m screwed.
完成的
Have same issue BUT watch does charge and connects via Bluetooth - so is alive but no vibrations or noise from find my.
Any thoughts? Thanks
完成的
添加一条评论
添加你的答案
christian hover 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 75
总计 3,658
