How to take a broken headphone jack out of the headphone slot?
My friend broke his headphone jack in the headphone slot, soo how do you take a broken headphone jack out of the headphone slot?
Hi Ben,
That situation happens often enough that they've designed a tool specifically for that job. Although you can find them many places like Amazon and eBay, you can support iFixit's repair efforts by buying it right here.
这个答案有帮助吗?
Thanks, but I already took it apart.
@nytryder26 you might be able to open it and push the broken pin out from the top of the connector
这个答案有帮助吗?
Are you willing to replace the headphone jack? If so, follow the dissasembly guide. Screw off the back motherboard after everything is taken apart, and then you should be able to just take the headphone jack out and put the new one in. They are loose, so no soldering required.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 1,236
3条评论
are you confident enough to open the controller?
由 Logixal 完成的
@logixal If I have to open the controller, sure.
由 NR26 完成的
@logixal Ok thanks
由 NR26 完成的
