跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
MacBook not entering internet recovery - 2100f
Hi
I have a Macbook Pro A1990 emc 3215 mid 2018 15" model. It has had its OS removed so I need to reinstall MacOS. No matter what keys I press it always boots to internet recovery (I've tried to do PRAM clear, CMD+R for recovery mode, Option key for boot options, D for diagnostics). When I enter my WIFI password it accepts it, starts loading into internet recovery but after around 30-60mins it fails showing error code 2100F. I have tried a power drain by disconnecting the battery and mais power but that has not changed anything. Does anyone have any ideas what is going on?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Is this a used system? I fear you have a iCloud locked system.
完成的
Yeah it is used, it could be locked but I have had locked ones before and I've never seen them behave like this
完成的
@christophe30013 Were you able to resolve this? I am also going through the same issue.? Any pointers are appreciated.
完成的
添加一条评论
3个答案
已选择的解决方案
@bagomac
Yes managed to resolve the issue in the end. I have had a good 10- 20 more devices doing the same thing and this has worked on all of them. It seems to me that the T2 security chip has become corrupted somehow, possibly during an update. You can refresh the firmware from another mac using this guide though and after that it seems to perform as expected.
https://support.apple.com/en-hk/guide/ap...
Hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
Time to visit an Apple Store to see if they can help you.
这个答案有帮助吗?
得分 1
添加一条评论
Hi
Have you tried installing macOS using another Mac onto an external hard drive then booting into it and installing with a installer from within the OS
That’s how I basically force a install on a stubborn computer
but if that doesn’t work I would do as @danj has said previously and take it to the apple store!
Hopefully this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christopher Summers 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 83
总计 8,840
