跳转到主内容
用于健康和个人护理的工具的维修信息。维修一般较为简单,只需用到常见的工具。
20 个问题 查看全部
How to change battery on Philips Lumea Prestige BRI956/00
Device will no longer charge. It lights up briefly if you hit the on button when plugged in, but that is the only time any lights come on. Charging light does not come on either. Model number BRI956/00
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Have a look at
https://lazyadmin.nl/diy/fixing-your-lum...
This may help
完成的
添加一条评论
3个答案
最有帮助的答案
The Lumea is closed pretty tied, first you will have to take off the lens cover. This way you can wedge something small between the seal, starting at 2, and work your way down to 4. Take your time for this, because there are some thin wires right beneath the cover, between numbers 3 and 4, on this side of the Lumea.
Disconnecting the battery pack
Once you opened the Lumea you can’t take out the battery pack yet, first, you will have to disconnect to PCM (protection circuit module) wire from the circuit board. You can just pull out the tiny connector. When done, you can disconnect the black and red wire on the battery pack itself and slide out the batteries.
Creating the new battery pack
As mentioned at the beginning, you will need 2 UR18650W batteries with C-type battery taps and a good soldering iron. The batteries may come pre-charged, so keep the covers on the positive side tabs until you are going to solder it.
We need the PCM wire for the new battery pack, so first, you need to desolder the wire from the old battery pack. The wire is also glued in the center, use a small knife to cut it loose.
New battery pack creation in steps
  1. Align the batteries
  2. Trip the long soldering tips to which you will connect the main wires and fold the other 2 tabs.
  3. Solder the tabs and connect to PCM wires as described below
For the new battery pack, we need to solder the positive and negative sides to each other. Trim the taps a little so they can overlap each other when the batteries are taped together. Then apply some tin to each tap where they make contact. Place the 2 together and apply some heat to it to solder the two taps.
Next, we need to reconnect the PCM wire, just simply solder the white and black where to the negative side of the batteries. When done you will have a similar result as below. As of last we need to adjust the taps for the main wires from the Lumea. I have chosen to cut them to the right size so I could reconnect the original connectors, but I have to say, they sit a bit lose, so you might want to solder them also.
When the battery pack is done, al is left the reassemble the Lumea. First, reconnect the black and white PCM wire, then the red wire, and last the black one. You might see a small spark when connecting the last wire, this is caused by the capacitor that will recharge.
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
Thank you @njaini for your nice reply.
Could you please add some picture to show what you mean with numbers 2 and 4 and from which side can we get it open.
For example, in this picture, you mean from side A or B?
这个答案有帮助吗?
得分 0
添加一条评论
Here are some images. The clips are VERY hard. I used the back end of a small spoon to get it unclipped because everything in plastic would just bend. To find out how it was clipped i just cut the silver ring, but it connects to the front part so should come out with it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cesca 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 81
总计 3,970
