跳转到主内容
An update released in May 2016 for Razer's 14-inch Blade gaming laptop. The first model in the series to feature a chroma backlit keyboard.
6 个问题 查看全部
Cable connector broken off motherboard
Hi everybody so the horror became real, during exchanging my battery in my razer laptop (14") the cable connector broke off the motherboard while disconnecting the cable that goes above the battery.
So within my moment of desperation, I want to ask if any of you see still a possibility to fix it, or do you think it’s a lost cause?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
I did the same thing lol. Did you ever find a fix?
这个答案有帮助吗?
得分 0
添加一条评论
No not really, but the laptop does turn on and it seems as if it only broke the battery indicator.
这个答案有帮助吗?
得分 0
添加一条评论
Same problem, those pins are too small to solder for me. Maybe some experts can do
The buttons below the touchpad didn't work after this, but I'm not sure if that was the cause
I hardly ever use those buttons but the mouse so I gave up on fixing it, I can't use right click without a mouse
Everything works fine except this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bernhard Lenger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 170
