跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
boot internal ssd problem
Hi everyone!
I have this A1708 for a long time. I’ve had to replace the batteries because they was inflated! Aside from this, I have another problem: for me to be able to boot from internal drive I must try 20 or 30 times to be able to recognize the drive! I’ve managed to format an external disk, installed Monterey and it boots all the time without problems, so, I think that the logic board is ok. Can someone experienced this behavior? Is it the SSD damaged or is the boot partition scrambled? After boot, it works ok and if I do several restarts it boots ok then.
Thank you for your help!
Regards,
Jorge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Using your external drive as the boot drive did you run Disk Utility Disk First-Aid to check the drive out?
完成的
@danj
Thank you for reaching out.
At the point you mention, the Disk Utility/First-Aid reports only the recovery partition (2GB?)
完成的
添加一条评论
1个答案
已选择的解决方案
Well thats not good! You’ll need to create a new primary partition using Disk Utility with the unused space it should be about the difference of the recovery partition and the total space of the drive as an example a 1 TB system should have about 850 GB if not then the drive is toast!
Who’s drive are you using the original or did you upgrade it? If you did who’s and how.
这个答案有帮助吗?
得分 2
6条评论:
Hi,
I'm using the original 500GB.
I think I'll get a new one. Any suggestions about price/quality?
Thank you!
完成的
@jorgebnunes - You have two choices, another custom Apple unit 512 GB SSD or 1 TB SSD or going with an OWC drive 1.0TB OWC AURA PRO NT
Sadly, the adapter and M.2 combo's some people have tried have not gone well as the custom data lines Apple has in their drives (and OWC) prevent excessive power loss and reliability.
完成的
@danj Thank you. I'll try the 512GB.
完成的
I recommend OWC
完成的
Hi guys!
Just got an OWC 1.0TB AURA PRO NT and it performs very well :-)
Thank you!
Best,
Jorge
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Jorge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 206
