跳转到主内容
The Logitech M305 is a wireless mouse released in 2010. It is designed for ambidextrous use.
5 个问题 查看全部
Why my Logitech mouse red light is flickering?
With time my mouse light is getting flicker. The cursor is shaking. Is it repairable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
Here’s what I found on a ‘dead’ mouse: The one lead of the LED had an obvious Dry Joint which I could pick up by visual inspection. Resoldering it made the mouse work again. I suggest you carefully resolder ALL the joint if the problem is not directly visible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
N.Jaini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 242
