跳转到主内容
加入维修社区 - 创建账户
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
iPhone 11 Screen Repair Question
I have been researching what I takes to repair my phone. I signed up for IFixit and looking at some tools to buy.  All the content looks great!
Quick question, what is the different between replacing just the clear portion of the screen of a phone and replacing the “screen” as you have it listed on IFixit website and in the videos.
Amazon, for example has kits on repairs that are less expensive but it only looks like they are replacing the actual clear portion of the screen. https://www.amazon.com/Replacement-Compa...
I don’t understand the difference.
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It's far simpler to replace the full LCD/Glass/Frame assembly. Even majority of repair techs will change like this.
To change the top glass, is called refurbishing, and this requires more specialised equipment, so for someone who does the odd repair, this isn't cost effective at all. So it's best to keep these working displays, and sell to a refurbishing company (I'll gladly buy them if in the UK)
To replace the top layer of glass, you'll need all the tools which you already know of for a replacement, plus the following:
Frame seperating tool - Different types, but most effective is a high temp heat plate designed to push the frame into it and soften the glue on the frame.
Vacuum heat plate - Holds the LCD down and heats the LCD so you can cut the glass off.
Various other bits like blades/chemicals/wipes/sponges.
Then you (ideally) need a mould for LCD/glass alignment.
A laminator (basic is around £450 and a decent one up from £1000)
Then a debubbler to remove any bubbles created from the lamination process. (You can get some of these machines which do the two together)
And the last bit, you'll need quite a few displays to practice on, because I can guarantee, when you first do one, it'll break.
Plaves like replacebase/iparts 4 u sell just the glass, bit it's really not suitable if you don't have the equipment.
Replace the full assembly, and sell the working display (if you get it off nicely)
Here's a video I've done for an XR glass/touch replacement. Should become clear what's involved then. https://youtu.be/tlng-9ONOP4
Definitely worth investing in if you are repairing alot of devices, your margins are considerably increased….. once you've nailed it.
Hope that helps you understand it a bit better 😁
这个答案有帮助吗?
得分 1
2条评论:
This was great. One follow up question, if I buy a full LCD/Glass/Frame assembly and replace it is it considered a refurbishment? Thanks
完成的
You could class the repair as refurbished with the full replacement of a complete LCD replacement, but not able to say OEM parts etc. 👍
完成的
添加一条评论
最有帮助的答案
Replacing the “clear portion” is generally just replacing the top layer of the display. Essentially on most phones, this is just protective glass, which is why it is less expensive because it does not contain portions that are necessary for the function of the screen. It’s just glass.
If that is the only component of the screen that’s damaged (so it just looks like cracked glass on top of a fully functional display and touch function is totally intact), it’s definitely doable. And WAY less expensive in many cases. However. It is a much harder repair to do without introducing additional damage to the display. Because this layer is adhered with very strong adhesive, it can be tedious and difficult to remove without hurting the underlying display components. It’s not something I would generally recommend for a repair novice.
这个答案有帮助吗?
得分 2
1条评论:
OK, I understand. I assume that explanation is why ifixit doesn't sell just the just the glass (as far as you know)? Thanks for the response!
完成的
添加一条评论
添加你的答案
Derek Skipper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 349
