跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Why aren't any diagnostic lights coming on.
I have a late 2015 iMac I purchased second hand, I upgraded to 512GB NVMe drive and I was installing Montery when the power went off. Now I’m getting no power on and no diagnostic lights.
I have checked with two other power supplies which are known to be working but no cigar. The power supply is receiving power.
Nothing was shorted and I can’t see any damage.
What would have cause this?
I’m dreading the quote from the tech shop that can do micro soldering
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I would pull the drive to see if it is messing you up.
这个答案有帮助吗?
得分 1
1条评论:
Why didn't I even think of that, I'm supposed to be a tech myself. It was working in an external apple blade enclosure but was extremely slow to put install Montery so perhaps you are right.
完成的
添加一条评论
Could 100% be the drive. Take it out or put in the old one and see if you get a light.
I will also note that since it is necessary on this model to pull the whole board out to put a blade style SSD in it could definitely be a board issue as well.
In order for that LED to light, you need the PP3V3_S5 power rail to be functional, so there is some doing on the board that is necessary before that light will pop on, even if the Power supply is good. Most of the components involved in generating that power rail are along the bottom edge of the board. So it is plausible something in that area was knocked loose when you took the board out or put it back in. I would take a look in this bit of the board specifically. In case you can’t tell, this is the lower corner below the cutout near where the RAM slots would be on the flip side of the board. I would check both sides. That specific chip generates the rail, but there are some components on the back which are part of the line that tells this chip to generate this rail. So either could be at fault.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Alisha, I feel silly for not ruling that out. I had it in an a usb enclosure and noticed it terribly slow towards the end to install Montery. I also had trouble with the option boot key when it was plugged in.
Hopefully this is the issue. I will keep you posted.
完成的
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 108
