跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
F23 code - Thermistor needs replacement?
I get F23 code on my kenmore elite dryer. Code means thermistor needs replacement. I replaced it and i still get the same error code. Should i replace the whole heater assembly ?
Update (02/18/2022)
model number is 110.C87892601
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
An F23 code could also mean that there is some other problem with the outlet thermistor circuit i.e. control board or thermistor harness wiring and not just a faulty thermistor
Here’s the tech sheet for the dryer.
On p.7 Test #4a it details how to check if the outlet thermistor circuit is OK
这个答案有帮助吗?
得分 1
1条评论:
i did everything, asked above. It worked for 3 cycles the the flashing pf23 code returned. this is very annoying.
完成的
添加一条评论
添加你的答案
simon benzekri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 585
