跳转到主内容
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
140 个问题 查看全部
My Kenmore stackable will agitate and wash but not spin.
My Kenmore stackable will agitate and wash but not spin. It also stops advancing the timer. If I let it go it will finish but it takes several hours and the water is gone but the clothes are soaked.
Update (02/17/2022)
Model 41799680210
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @profkenmore ,
Check if the idler pulley is OK and is exerting enough tension on the drive belt. Also check if the drive belt is OK i.e. no cracks, splits etc.
The supplier link above is only to show where the part is located and how much it may cost. If it is the problem there are other suppliers online that may suit you better. Just search for 131862900 to get results. (Note: your Kenmore combo unit is either a rebadged Frigidaire unit or a made to order unit for Sears by Frigidaire, not sure which, that’s why the part will appear as a Frigidaire/Electrolux part in the search results).
Bit confused when you say “It also stops advancing the timer. If I let it go it will finish…..”. Does the timer start up again or what happens to make it finish the complete wash/rinse/spin cycle and not continue doing whatever where it’s stopped at? Does it stop in the spin section of the washing cycle, with no spinning action?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Professor Kenmore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 371
