跳转到主内容
The Lexus IS is a compact executive car sold by Lexus since 1999. The IS was originally sold under the Toyota Altezza nameplate in Japan from 1998.
Why is my IS giving a knocking sound
My IS250 suddenly giving a knocking sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
I'm afraid you're going to have to give us more information if you want a useful answer. Here are a few suggestions for things you could tell us that would help figure out what's going on with your Lexus.
When do you hear the sound? Is it when the car is moving or just idling? If moving, does it vary with road speed, and if idle does the engine speed affect it?
Whereabouts is the sound coming from? Front of the car or rear, left or right, inside or outside?
Is it a thumping or more of a tapping sound?
Was anything done to the car or anything happened to it prior to the start of the noise?
Are there any DTCs (Diagnostic Trouble Codes) present? Have you scanned the OBD-II connector?
完成的
添加一条评论
2个答案
check rear sunshade if its knocking when or after close or open morover if hear it when u are moving while the sun roof is down it's may need to replace the Sunroof Seal.
这个答案有帮助吗?
得分 0
添加一条评论
It’s making a knocking sound while I’m turning the steering wheel
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Earthplus Autos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 396
