跳转到主内容
加入维修社区 - 创建账户
My display doesn't work on my Asus FX505D laptop.
I tried reseating ram, reseting bios, a hard reset and still nothing. I’m so confused because it was working fine a couple of days ago and I did nothing to damage it. I can never find videos on it its like my laptop doesn’t exist
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
Are you sure that it is an FX505D and not an FX505DD, DT, DU, DV or DY?
Try connecting an external monitor (TV?) to the laptop’s HDMI port and check if there is a display on it. Don't forget to press the Fn+F9 keys (both together) to toggle the display from laptop only to external only to both on.
Here's a link to some videos that show disassembly of various FX505D series laptops that may help.
这个答案有帮助吗?
得分 1
6条评论:
Ive tried this im not sure what the problem is the fans sometimes dont come on but when i reboot they do but still no display
完成的
@Weekdays_
Sounds like it's not booting more than a no video problem.
What did you do as a "hard reset"?
if you meant the 30 second power button pressed with the main battery disconnected or removed you may have to try a complete power refresh to reset the BIOS.
Looking at the videos I linked there appears to be a coin cell CMOS battery on the motherboard.
So, disconnect the charger if connected.
Disassemble the laptop to disconnect the main battery - you only have to disconnect it not remove it
Remove the coin cell battery from the motherboard (Note the orientation of the battery - usually it is +ve on top)
Press and hold the power button for a full 30 seconds and then release it.
Reinsert the coin cell battery. Remember the orientation when inserting
Reconnect the main battery
Re assemble the laptop.
Connect the charger and try turning it on and check
完成的
My keyboard lit up but when i press the power button it doesnt boot up or turn on
完成的
@Weekdays_
Have you tried what I suggested above?
With all power removed from the motherboard i.e. charger, main battery, CMOS battery nothing should "light up" or turn on as you are draining any residual power from the board in an effort to reset the BIOS back to its factory default state.
完成的
Yes i tried what you said too thats what happened after i put it back together i did it again to make sure but it went back to no display and no fans
完成的
显示更多的1条评论
添加一条评论
Try and remove the screen connector and any unecassary components
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Weekdays_ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 766
