跳转到主内容
苹果的第四代无线键盘 发布于2015年10月 型号A1644
How to fix the power button? It slides and not click.
How do I fix the power button? I opened the backing but now there is a screw that I (might) need to remove to get to the power corner. It slides instead of the normal click (left to right) to power on,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Talking from experience here, I just dissasembled mine a few minutes ago for a hardware problem, while I was attempting to take the lid off the Aluminum chassis, I accidentally torn the power button, which ended underneath the inside "beehive plastic cover".
Whe it was time to re assemble everything, I put back the power button on the top left corner, which is actually where It should be, and turned to just be held by a crappy plastic piece, which shafts the sliding movement to an actual switch, connected by a ribbon cable to the keyboard board.
Haven't searched yet, but I don't really know where I could buy this pretty specific thing, unless I get it 3D printed. Since we have the same problem, if I get it solved I'll tell you how to do so.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mona Masri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 173
