跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
Compass functionality not spinning/working
Using either the Compass app for PhoneDoctor app to test the compass functionality and it seems like it is not working. Other functionality does seem to work fine; gyroscope, accelerometer, etc. Done a factory reset, DFU restore, nothing.
What could possibly be the problem? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Maybe use a sensor data output app to see if the gyro is actually working, if it works, then check magnetometer data.
这个答案有帮助吗?
得分 1
3条评论:
The gyro and accelerometer seems to be working fine on a different app, though the magnetometer doesn't seem to be responding to any changes :(
完成的
@remster9000 I use this app to check sensor data: phyphox
完成的
Managed to get around for this! So I checked with the app you use and it seems like Acceleration (without g), Gyroscope and Magnetometer doesn't seem to be showing any data.
完成的
添加一条评论
添加你的答案
Remy Stark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 114
