跳转到主内容
The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
28 个问题 查看全部
Right turn signal works oddly.
So, if we start the card and turn on the right blinker. It seems to work o.k. However if
turn on the headlights and check the blinker, no go. The front one works (fast) but no back blinker. Turn off the head lights, and the symptom stays. Looking at the wiring diagram shows that the lamp is operated by a unified electronic module. So, is it possible that the lamp has a bad ground or lead wire that shows open when the headlights are on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
A rapid turn signal indicator light light is usually a sign of a faulty bulb or connection etc in the circuit front or rear.
if it is always the rear turn signal light that doesn’t work, check the bulb/bulb connection. It may be a faulty bulb (filament?), a lack of tension between bulb and holder, corroded, or have a bad earth
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay Cotton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 45
