跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
71 个问题 查看全部
How do I repair steam flat irons
Is there a common failed part for steam flat iron
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, when the iron gets too hot the thermal fuse will blow to protect the heating element. They can be replaced with the same value. No soldering here, only use appropiate wireclamps for high temperature purposes. Thermal fuses can fail due to a failing thermostat (the rotary knob you set the temerature with), so you probably have to solve the cause of the problem as well.
Measure the thermal fuse with a multimeter, they should measure 0 ohms. Open means defective. Thermal fuses are usually mounted near the heating element. If thermal paste is used, make sure there’s enough left when you mount a new one for optimal thermal protection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 62
总计 301
