How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
这个答案有帮助吗?
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 21
总计 216
6条评论
Do you have a hot air station?
由 Andrew S 完成的
nope
i guess i'll just replace the motherboard
由 notnice -96 完成的
i'll need to back it all up
由 notnice -96 完成的
@andrewsawesome what if i did?
由 notnice -96 完成的
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
由 Andrew S 完成的
显示更多的1条评论
