跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Keyboard and trackpad not working
I changed my battery carefully, and after that Keyboard and trackpad stopped working.
This seems to be a common problem and I have spent a lot of time going through all proposed solutions without success.
I did all the boot resets suggested. I bought a replacement flex cable, which didn’t do anything. I then bought a replacement trackpad thinking that was the problem, again with no success.
At this point I am thinking maybe I screwed up the motherboard. I have not replaced the keyboard as I assumed since the new trackpad didn’t work the issue is not the keyboard.
Any suggestions? Computer works fine with bluetooth keyboard and trackpad, but not the built-in ones.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
did you follow this guide? Retina MacBook 2015 Battery Replacement
Did you note the warning?
To avoid logic board damage, when your Macook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable. These accessories are not included with your MacBook, so make sure you have them ready before you begin.
See if that fixes things.
这个答案有帮助吗?
得分 0
1条评论:
I did not actually. So maybe I fried something. After that initial battery replacement every time I opens the laptop I did do that step, but not the first time.
完成的
添加一条评论
添加你的答案
M S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
