跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Cellular connection not working
AT&T locked had them unlock put in new provider SIM card got only wi if calling and no service did all the resets and it keeps asking to update carrier settings push yes still nothing went away from house where wi fi is and tried all resets now no wi fi calling or cellular help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
hello Joe,
start by checking the radio subsystem: press *#06# on the keypad. Write down what appears on the screen. Then go to settings - >> general - >> this device scroll down. Find the position of the firmware modem and imei. It will be important what these numbers look like. This way you will confirm whether the radio system works in the phone or it has been previously damaged (what happens sometimes). y speaking, when the phone asks you to update the operator's data, there is a suspicion that the communication system is damaged. In 6s, the repair is rather standard and quick. It shouldn't be expensive anymore (it's 2016 phone).
这个答案有帮助吗?
得分 1
2条评论:
Thank you the numbers match if that’s what should be? Still no go suspect what you say is correct Should I take it to Apple repair? Don’t have tools or skills to attempt Thanks again
完成的
If you see the numbers next to the modem firmware and the imei is correct below, then it's okay. Enter *#06# again - if imei appears, the radio service is working properly. You should be technically able to receive the signal. If you are still unable to start the connection on the activated phone, the problem may be with the sim card or its permission to work with that phone (operator lock for overdue payments, errors due to unlocking or something similar). Sometimes it helps to remove the sim card and wipe it's contacts.
完成的
添加一条评论
添加你的答案
Joe Kenneally 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 112
