跳转到主内容
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
28 个问题 查看全部
Why am I not getting power to my fuel pump? I have replaced the batter
Not getting power to fuel pump 2005 Ford explorer xlt.
Battery,Fuses,fuse box relay, Emergency shut off fuse,fuel pump drivers module,fuse for fuel pump,fuel filter, fuel pump and crank sensor all have been replaced and still I am have no power to the fuel pump at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi, I found this when I was browsing around a bit for some info.
I would start by checking the fuse in the fuse panel under the dash, and look for if the fuse F9 is intact (2A)
Then I’d check the fuel pump relay in the Battery Junction Box, if that operates as intended.
Hope this helps.
If you have more info to provide, you can always update your question with more info.
*Edit, removed broken link
Your car seem to have an electronic shutoff switch in case of a collision, have you checked that it’s not active? Ford explorer 2006 Owners Manual pg244
这个答案有帮助吗?
得分 0
添加一条评论
Did u try give power to fuel pump with prob tester ? To me this is some grand issues or PCM u have to check wiring from fuel pump to PCM
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laura Ock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 1,017
