跳转到主内容
The Lenovo Yoga Book X90F is a compact, portable device designed by Lenovo. The device comes with a pencil and is capable of being a laptop or tablet. Model number: Lenovo YB-J912F.
2 个问题 查看全部
YB1-X90F Not Booting into OS - Flashing Help [Android]
TL;DR: Noob needs to stock flash a device that won't boot into OS. How is that possible if guides steps tell you to enable the "Developer options" and "OEM unlocking” on a working phone?
Fault: Powers on, shows the orange Lenovo splash screen, then it’s just blank. I can access the bootloader and recovery.
I’ve asked this over at XDA and a subreddit with surprisingly with no response. There was also another person with what seemed to be the same issue, no reply.
I acquired this and a Huawei MediaPad M5 8.4 SHT-W09 with the same type of issue. Not booting into OS. The M5 was really easy. Just added a file(s) to an SD card and run it from the recovery menu.
Doesn’t seem to be that simple with this though. But I am a noob.
I took me ages to get a working driver for ADB. Seems to be working now. (Mentioned in the XDA link.)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Solved. I ran 'flash_update_from_user.json
Just waiting for the battery to charge to 30% to hopefully enable the Halo Keyboard.
Here are the files needed in case other links void in the future: https://drive.google.com/drive/folders/1...
Edit: Android N update bricks it for some reason.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paft 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 517
