跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2399 个问题 查看全部
4s Back Panel Is Stuck On
I have removed both screws, but the back panel will not slide up. I’ve tried increasing pressure, cleaning the sides with alcohol and increasing grip with some gaffer tape. I can’t replace the battery if I can’t open it. What am I doing wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery is probably expanding and putting pressure on the back glass making it harder to slide up. I would try putting the phone face down on a non slip surface like a rubber mat or something then slide the back up while putting slight downward pressure on the phone.
这个答案有帮助吗?
得分 0
2条评论:
Hi Jay, I'm jumping in on @xnriqux's answer. If you think the battery could be swollen, make sure to be really cautious working on you device. A swollen battery is quite dangerous–it can be a serious fire hazard. Check out our wiki on swollen batteries before you attempt your repair so you can be extra cautious! What to do with a swollen battery
完成的
@amber Thank you!
完成的
添加一条评论
添加你的答案
Jay Hackens 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 36
