跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Attaching Brave Disk Image for Install - Is My Computer Hacked -
I’m still trying to figure out the deal with this computer. Please look at the following code. To me it looks like a checksum is performed to verify the disk image is the correct malware, then it installs some malicious device drivers. Also, I mapped this drive to be APFS. I’m not sure why HFS is showing up. Any help would be great.
Here is the code too. I’m surprised the Brave disk image is being called 89UUIEOFWEW. S is what I named the hard drive.
jonathannormal@Jonathans-iMac /volumes % ls
jonathannormal@Jonathans-iMac downloads % cd /volumes
89UUIEOFWEW s
jonathannormal@Jonathans-iMac /volumes % hdiutil attach /Users/jonathannormal/Downloads/Brave-Browser-x64.dmg
Checksumming Driver Descriptor Map (DDM : 0)…
     Driver Descriptor Map (DDM : 0): verified   CRC32 $B7D1E44D
Checksumming Apple (Apple_partition_map : 1)…
     Apple (Apple_partition_map : 1): verified   CRC32 $6E33BD26
Checksumming DiscRecording 9.0.3d5 (Apple_HFS : 2)…
DiscRecording 9.0.3d5 (Apple_HFS : 2: verified   CRC32 $E5D41205
verified   CRC32 $732677D7
/dev/disk2          Apple_partition_scheme
/dev/disk2s1        Apple_partition_map
/dev/disk2s2        Apple_HFS                      /Volumes/Brave Browser
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What is the macOS version you are running, also post a snapshot of your volumes and disk drives.
You appear to have a Disc Recording app running what else are you auto loading.
完成的
添加一条评论
1个答案
此回答最初是针对另一个问题
I recommend you find your way to an Apple store to have them help you =rebuild your system as you clearly have some apps which have been broken into with malware threats!
You will need to make sure you completelyt wipe your internal drive and re-install from the App store as well as known safe apps from major vendors. I wouldn’t install anything from Github at this point as I =encountered some strange stuff a few months ago. My Anti-virus and malware tools flagged it and I removed it..========
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33
