跳转到主内容
Designed in 1991, the fourth generation Maxima arrived in May 1994 for the 1995 model year as the A32.
7 个问题 查看全部
Why does my car die when put in gear?
It starts great. Stays running but when put in gear & given gas, it's dies & when I push the gas petal it doesn't go anywhere & acts like it's not getting any gas! Please help! ,?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
An automatic car can stall when put into gear for countless reasons. It could be a result of a faulty coolant sensor, bad alternator, empty fuel tank, bad fuel pump, leaking vacuum when the filter is blocked, etc.
这个答案有帮助吗?
得分 0
1条评论:
If the vehicle idles for several minutes without a problem, and only dies when put into gear, it's probably not a fuel pump or fuel tank issue.
完成的
添加一条评论
添加你的答案
Shonda Hayes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 47
