跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
209 个问题 查看全部
Will surface pro 4 work without a battery inside?
My surface pro 4 has swollen and i can't replace it for the moment. I was wondering if i could keep on using it just with the power supply plugged, removing the battery.
If so, what special precautions should i take?
Thanks for your advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I can be wrong or right, if you did remove the battery then it is possible for it to run just by the power supply, I don’t think there should be any problems if the battery is removed but if you didn’t remove the battery then please be careful when removing it. remember i may be right or wrong
这个答案有帮助吗?
得分 0
添加一条评论
Hi.
Yes, I can confirm that the tablet works without a battery on the charger, I've tested it. BUT to do this you'll need to dismantle the tablet almost completely to remove it, following the very good but also very difficult ifixit tutorial here (in the language of your choice) => https://fr.ifixit.com/Tutoriel/Remplacem...
And it will then be a good idea to replace the battery with a new one, with the caveat that it's often difficult to find really new ones, even from ifixit (see my comments here):
https://fr.ifixit.com/R%C3%A9ponses/Affi...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nahuel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 499
