跳转到主内容
Repair and troubleshooting information for the HP Envy x360 m6-w laptop computer.
10 个问题 查看全部
Is it hard to change the screen on these?
I have slight water damage on the bottom right of the screen and it still works but the screen seems pixilated where it happened. I have put a screen on a lenovo before but I'm just worried about the touch screen element of the job.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Here’s the maintenance and service guide for the laptop.
Go to p.49 to view the necessary pre-requisite steps and then the procedure to remove the display assembly and then the LCD panel.
It appears that the display panel comes as a complete module comprising both the LCD panel and the touch panel and not as two separately removable panels.
On p.50 (also seen on p.19) you will find the spare part numbers for the available display panels. Search online using the appropriate part number only in the search box of your browser to find suppliers that suit you best. If you wish to verify that you’re ordering the correct one for your particular model, usually the part number can be found on the back of the panel somewhere.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ardara . Ie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 154
