跳转到主内容
Repair and disassembly information for Razer keyboards.
Is there a way to fix this connector?
My Razer Cynosa’s spacebar isn’t working. After a lot of trying out I finally found this connector directly conencted to the spacbar on the board. It seems that it is just not connected and therefore there can’t be any input from my spacebar. Now the question obviously is, if there is a way to fix this by myself. Thanks!
Here is the picture:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There are a few ways to try to fix this:
Fill the gap with solder (put solder on the broken track and take of the excess with solder wick)
Use conductive paint to repair the pad
Run a jumper wire from the cable to its respective pin on the connector
Let me know if you need more details.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! This sounds good! If I've got any further questions, I'll get back to you :)
完成的
添加一条评论
添加你的答案
Mattis Ba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 185
