跳转到主内容
加入维修社区 - 创建账户
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
My MacBook won't turn when got cold till I heat it?
I have Macbook Pro Mid 2014 Model A1502 yesterday I shut down and it was full charged unfortunately today I have tried to turn it on but it didn’t work till I heat it well I don’t know the problem is humidity affected the Logic Board or what some people say it’s Logic Board if somebody has experience helping me to fix it thanks so much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
More likely the battery needs replacing.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
@danj thanks so much for your recommendation I appreciated it, I have attached the screenshot of the Battery.
完成的
添加一条评论
1个答案
已选择的解决方案
Yep! New battery time! Between the number of Cycles over the 1,000 expected life span. As well as the age original battery from 2014 eight years on!
Here’s the needed battery MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery and the guide to put it in MacBook Pro 13" Retina 显示屏 2014年中期 电池更换
Replace a 6600 mAh battery compatible with MacBook Pro 13" Retina Late 2013 to Mid 2014 A1502 model laptops. 74.9 Watt Hours (Wh). 11.42 Volts (V).图片
产品
$89.99
这个答案有帮助吗?
得分 2
1条评论:
I am grateful for your help and for taking the time.
完成的
添加一条评论
添加你的答案
Mahdi Ibraheem 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 74
