跳转到主内容
Repair information for the 2017 Toro Compact Stump Grinder with model number 22600HD or 22600, and serial numbers from 316000001 to 316999999.
Step 13 - replacing the centrifugal clutch - remove the bolt
I saw the guide for replacing the clutch written by Sam Omiotek. I am at step 13 where it says to remove the bolt from the end of the crankshaft. But it doesn’t say how to hold the crankshaft. The bolt spins the crankshaft so there’s no torque available to remove the bolt. How do I keep the shaft from spinning while unscrewing the bolt? Help!
If you will email me directly I would much appreciate it. michael@bolincpa.com Or office phone 325-632-2011. Central time zone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I usually use a good box end wrench. position it so you can wack the end of the wrench with a hammer. similar to using a impact gun.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MICHAEL T BOLIN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 316
