Kenmore Elite HE washing fails intermittently with an f20 error
During the rinse cycle my Kenmore Elite HE3 washing machine fails intermittently with an F20 error code. I can reset the washer to a different place in the wash cycle and it will continue . It doesn’t always do this but seems to happen more frequently when I put in a large load. I’ve tested the continuity on the inlet valves and they are ok. Does anyone have any suggestions.
Update (01/26/2022)
The model number of the washing machine is 110-47571602. There was a little bit of guck on the hot water inlet screen which I removed. It would have covered less than 10% of the screen at most likely closer to 5%. The water pressure is fine at least 60psi.
2条评论
Hi @meconopsis,
What is the model number of the washer?
Have you checked that the water pressure at the output of the inlet hoses is OK and also made sure that the hose screen filters are clear?
由 jayeff 完成的
F20 appears to indicate insufficient water supply. Make sure hoses are not kinked.
由 Ken Grubb 完成的
