跳转到主内容
加入维修社区 - 创建账户
How to convert replacement battery pack, 4-pin jst connector to 3-pin
Hi there, my mobile router battery recently swelled and I needed to replace it but could only find a replacement that comes with a 4-pin jst wire connector however my previous battery had a 3-pin jst wire connector. Am I able to convert the 4-pin into 3-pin so that it will be able to slot in, on the mobile router circuit board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi,
What is the make and model number of the mobile router?
What is the full model number on the battery that was in the router? (printed on battery)
Converting 4 wires to 3 might not be safe to do if you don't know what the functions of the battery wires are, more so the yellow and the white, assuming that the red and black are the +ve and -ve leads.
You could end up with a fire or overcharging the battery and damaging it, if you connect it incorrectly
完成的
@jayeff hi thanks for your help. The mobile router is a ZTE MF910. The battery model number is Li3823T43P3h715345
完成的
添加一条评论
4个答案
最有帮助的答案
Hi @theshen
Search for Li3823T43P3h715345 (supplier examples only) to get results for suppliers that suit you best
这个答案有帮助吗?
得分 1
添加一条评论
Um einen 4-Pin JST-Batteriepack auf einen 3-Pin-Stecker umzuwandeln, müssen zuerst die Leitungen identifiziert werden:
  • Rot = V⁺ (Plus)
  • Schwarz = GND (Minus/Masse)
  • Weiß/Gelb = Sensor oder Balancierung
  • Die zusätzliche Leitung wird je nach Gerät eventuell nicht benötigt.
Nur die drei erforderlichen Leitungen (meist Plus, Minus und Sensor) in ein 3-Pin-Gehäuse einsetzen und die Belegung vorher mit einem Multimeter prüfen, um Schäden zu vermeiden.
Mehr Details findest du in diesem Leitfaden auf Kasuo
这个答案有帮助吗?
得分 0
添加一条评论
  • Rot = V⁺ (Plus)
这个答案有帮助吗?
得分 0
添加一条评论
To convert a 4-pin JST battery pack to a 3-pin connector, first identify the wires:
  • Red = V⁺ (positive)
  • Black = GND (negative)
  • White/Yellow = sensor or balance lead
  • Extra wire may be unused depending on the device.
Re-terminate only the required three wires into a 3-pin housing (usually V⁺, GND, and sensor if needed). Always confirm pinouts with a multimeter to avoid damage.
For more details on how 3-pin connectors work, see this guide on Kasuo
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Theshen Moodley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 51
总计 1,717
