跳转到主内容
加入维修社区 - 创建账户
27英寸显示屏,分辨率为 2560 x 1440 像素 Thunderbolt 与 MagSafe 线缆连接
Black screen, but fan and Magsafe operational, PSU pinout tested OK
All right, so I bought a dead Thunderbolt display 27” (for 7 EUR) and I want to fix it and would appreciate any help or comments.
What works:
  • Magsafe charging works.
  • The internal fan is running, and since it’s getting power and signal from the logic board, I reckon the logic board is not entirely dead.
What doesn’t work:
The display, USB etc is not recognised by the Macbook Pro. The display does not show any kind of image. The computer doesn’t even react (i e flicker) when the TB cable is inserted/pulled out. This MBP works perfectly with other Apple displays.
My questions:
  1. Any tips on where to get hold of a Thunderbolt 2 cable to see if the internal one is bad? I don’t want to spend 25-30 EUR on a cable if that is not the issue.
  2. If anyone has a replacement glass, I am interested in buying..
  3. Is there any kind of fuses or similar safety feature that would cause the logic board to not power up?
  4. Any tips on troubleshooting the logic board further?
Update (07/25/2022)
I successfully repaired the display!
The problem was the All-in-one-cable.
I suspected the cable after visually inspecting the PSU and logic board, which looked fine. I also measured correct voltages coming from the PSU, and also seeing that the logic board spun up the fan, so it seemed to be at least somewhat functional.
The AIO cable was 25 EUR from eBay and the display now works perfectly!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Really happy to hear that you were able to solve the problem, congratulations! :D
To make it easier for others to solve the same problem, please copy the update message and post it as an answer. Then mark your answer as the solution to your problem.
完成的
@eke0909 Thank you for showing me the ways, updated as suggested!
完成的
添加一条评论
2个答案
已选择的解决方案
Update (07/25/2022)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
In a darkened room when you turn on the display do you see a bit of a glow? If you do that is telling us the backlight is powering up. If not then I’m suspecting you have a power supply issue as this display has two power feeds 3.3 V DC & 5.1 V DC its possible one has failed.
  • Google: LED Cinema Display 27" (A1316) Apple Technicians Guide
Which is similar to the Thunderbolt display and can be found.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
olovkallgarn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 692
