跳转到主内容
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 个问题 查看全部
Im at a dead end and really need help
My 02 ram 1500 5.9l gas died as i was driving yesterday . I have fuel pressure and the coil has spark going to distributor. It turns over and sounds normal cranking but wont start. Recently ive replaced the fuel pump and coil along with distributor wires and rotor all have under 600. Any suggestions ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @dirtyboot,
Check the OBDII codes. There may be a problem with the camshaft position sensor (P0340 code) or the crankshaft position sensor (P0335 code)
If it is the camshaft sensor, here’s information from the service manual that may help.
(click on images to enlarge)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
BrandonV 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 8
总计 72
