Screen wont respond after battery replacement.
Changed battery, tried plugging in screen multiple times, cleaned with a q tip does not work.
If i’m looking at the photos, it seems like that there is a gold pin missing in the last picture. Besides that, what are those white strings at the logicboard? Hair?
Have you already tried a new screen?
这个答案有帮助吗?
Disconnect the screen and look for any debris between the connector from the display and the logicboard.
Also, check if it clicks like Lego. If you did both steps, you probably damaged the flex cable in some sort way. This is the right/lower flex. You must then buy a new screen.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 85
3条评论
Have you tried installing the old battery and testing again? I've had this issue and it turned out to be pressure damage from pushing the connecter in with too much force. It would pay to test another screen as well which would be easier for a repair shop to do.
由 Eric 完成的
The screen does work and it goes on with my saves screen saver, It won't respond to the touch or the swipe.
由 Jake Wal Wal 完成的
The screen has 2 cables. One for the display and one for touch. The smaller cable is for touch. are you able to send us some photos of the board connector and touch connector?
由 Eric 完成的
