My airpods isnt charging
The red charging light on the airpods case isnt showing and neither the airpods are charging
From what I can guess is that the battery or the charging port in the case could be defective. You could try using the wireless charging and see if the device charges. Unfortunately their isn’t an easy way to repair these. I do encourage that if the device is still under warranty that you bring it back to the seller and report the issue.
这个答案有帮助吗?
I would also see if the port has any debris in the actual port itself and try cleaning it out.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 103
2条评论
Hello, does the light change when you plug the case in?
由 Jacob Mehnert 完成的
No there’s no light when i plug in the charger
由 Namir Shah 完成的
