跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Can I upgrade to Bluetooth 4.0?
I recently saw the upgrade of MacBook Pro 2010 to Bluetooth 4.0 using the 2012 version of airport card. Will it be possible on my MacBook?
This is the bracket I saw. Will it be compatible with BCM94331PCIEBT4CAX?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sometimes things look like they could be swapped out but just can’t!
So let’s take a deep dive into the two systems AirPort boards. If we look at the two we see quite a few physical differences:
MacBook AirPort
MacBook Pro AirPort
There are four antenna connections the location of the data cable is different as well as the mounting points and what is not seen is the dimensions of the board is different.
Is the effort of trying to make this work worth it?
We still don’t know if the pinouts of the cable are compatible and if the OS will recognize it.
这个答案有帮助吗?
得分 2
2条评论:
It seems impossible, thank you..!
完成的
@ajsa124 - Sorry Apple doesn't always make it easy. Don't forget to accept the answer - Thanks!
完成的
添加一条评论
添加你的答案
TS Ryu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 177
