跳转到主内容
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
Why won't dualshock4 charge (hardware repair)?
To preface, it is not the PS4, I have other controllers that connect, charge, and play just fine.
This controller had been opened before (new thumbsticks and triggers) but after years of use it all of a sudden wouldn't charge. I bought a new USB charging port socket board and 12pin flex cable (yes, it's the same model) and replaced that. Still nothing. So I took a good charged battery from a different controller and put it in this one, it powers and plays fine but still won't charge. The connection is there though with charging port socket board as the controller light works. So if it's not the battery and it's not the charging port.. what is the problem? Oh, and while it won't charge, occasionally when I've tried to charge it I will get a “too many USB devices connected” prompt. And again, it's just this controller. Others work fine..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be that the motherboard of the controller maybe failing. Commonly not charging is either due to busted USB port, dead battery, or a torn flex cable and since you have already replaced all of that then it maybe safe to say the issue is with the motherboard itself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean Flanagan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 384
