跳转到主内容
Drum set accessory to the Wii game, The Beatles Rock Band, which was released in 2009 by Harmonix. This repair guide will give you help on fixing and/or replacing certain parts of the drum set. Identified by model number NWDMS3.
2 个问题 查看全部
Will not power on
Recently got out of storage. There was some corrosion on the battery contacts, when cleaned off all connections were checked and there appears to be no damage inside the wire casing. Tried several different batteries. Looking for suggestions, or if it is a lost cause.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You could put a multimeter in DC voltage mode and check to see if battery voltage was making it to the actual circuit board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jared P Neslen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 126
