跳转到主内容
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
46 个问题 查看全部
Why is my screen glitching during gaming
When i am gaming on this phone (Samsung Galaxy J5) even on 60 fps the screen will either freeze or if i was moving my finger on the screen the display will recgonize that my touch is still there even tho i put my hands of the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rugdug,
Try using the phone in safe mode and check if it works better.
If it does a downloaded app is the cause of the problem. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to see if it works OK. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed onthe phone and wasn’t pre-installed on the phone when you first got it.
Also if it only happens on one game it may be that the phone doesn’t have the system resources to play it properly so it glitches or freezes because it can’t cope.
这个答案有帮助吗?
得分 1
1条评论:
Yes, that is a good solution. It's actually what I was going to say.
完成的
添加一条评论
添加你的答案
RugDug 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 60
