跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
577 个问题 查看全部
Thunderbolt 2 cable connecting to usb?
Hey guys
I have an audio interface that runs with thunderbolt 2, but I am wanting to be able to plug it into my USB port rather than thunderbolt port, so that I can still use an external monitor. I’ve exhausted google. Do you have any suggestions? Is this even possible? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Thunderbolt 2 is not compatible with USB. As there doesn't seem to be any solution to convert Thunderbolt signals to USB, I don't think you can use a Thunderbolt 2 device in a USB port.
这个答案有帮助吗?
得分 1
4条评论:
Thanks for your answer. Is there a way to connect hdmi to either usb or FireWire on my Mac to free up the thunderbolt port ?
完成的
@keeze - Sorry, same story different channel ;-{
FireWire is an old standard and was strictly external drive access.
USB 2.x which is what this system offered does not offer any video output.
Sadly, you'll need to look at changing your direction. How about getting a USB case to hold your drive to free up the Thunderbolt port.
完成的
@danj unfortunately I don’t think that’s an option. The interface in question is an Apollo twin mk1 which doesn’t support usb. Is there such thing as a usb to hdmi with a mini graphics inside that would work with my MacBook?
完成的
@keeze - Sorry no such animal ;-{
完成的
添加一条评论
添加你的答案
Ben Kelso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 85
