跳转到主内容
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 个问题 查看全部
Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
完成的
No, it’s when I put a cartridge in on any surface
完成的
添加一条评论
2个答案
最有帮助的答案
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
这个答案有帮助吗?
得分 1
添加一条评论
Before replacing the slot, you could try a trick to clean the card reader pins first.
  • get some isopropyl alcohol and thoroughly soak the contact points of any cartridge with a Q-tip.
  • put the cartridge in the slot and insert/eject the cartridge repeatedly for about 3 minutes.
  • try it again and see if that fixed it.
hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Bitzas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 193
