跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Transparent screen not quite flush?
The iPhone 4S transparent back doesn't sit quite flush w/ Verizon iPhone 4S. It appears to be off by a fraction of a millimeter, enough so that the flash isn't centered with the hole.
I would need calipers to measure the minute distance. The best indication is that the camera and flash holes aren't perfectly dead-centered over the elements.
I have removed/reattempted several times, verified that there aren't any manufacturing boogers or burrs on the catch-ears.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Very common problem with conversion kits. Take the screws from the back plate out. Take the phone in your hand and push the the side that is hanging over againt a table or something until everything is flush like you like. Dont worry you wont hurt the phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eric 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 13
总计 728
