Can flexible be fixed?
I touched the flex cable as you can see it on the picture any chance to get it fix?
Update (01/12/2022)
I hope these pictures are more clear.
All depends how good you are with micro-soldering
It is possible and I know of people that can do it but I wouldn't call it a permanent fix as can always break again.
Would probably be better changing the full thing.
这个答案有帮助吗?
The ribbon cables are very fragile, more likely the cables pad has been ripped off so its just not there to re-attach as its gone.
Looking at the new uploaded picture I would agree with @danj the pads looks like they have been ripped off.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 170
4条评论
The images are not clear enough to see any damage.
Lets cut to the chase, is the display working or not? If not then you have no choice you’ll need to replace the display assembly. If the display is working then you only damaged the chin plate which can be replaced.
由 DanJ 完成的
The screen works the camera, blacklight except the image. Do you have an image of the chin plate?
由 Yass O. 完成的
@yas_surfer - You damaged the inner cable!
The chin plate is just a thin glass cover A1706 A1708 A1989 A2159 LCD front bezel logo cover for 13" MacBook Pro
由 DanJ 完成的
Yes, you mean the a1706 bezel, yes
由 Yass O. 完成的
