跳转到主内容
加入维修社区 - 创建账户
2013 年发布的咖啡机。Keurig K40 是一款兼容 K-Cup 的咖啡机。
Why wont my keurig make a full cup of coffee?
hi … i have a keurig k40 …that every couple months decides to not make a full cup of coffee … tried everything shown in info i seen on this site…last couple times i had this problem …on the top theres a check valve that i took apart ..cleaned etc and watever i actually really did im not sure ..but works than for a month or 2 same issue …would it help changing check valve ? or would this k40 have a solenoid that could be causing issue ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hello, does this issue happen when you use a K-Cup or do you use one of the reusable cups?
由完成的 分享
i would say it happens with both k-cups and reusable cups ...also if i just fill a cup of hot water alone .. does this as well...
由完成的 分享
The water flow is not at the desired level. It can be a clogged inject needle, it can be a leaking flow valve, It can also be you did not seat the pod fully and punched an out flow hole in the pod. the clean needle and bottom hole are easy to inspect. the flow valve is difficult to replace. you should see the water over flow returning into the water tank.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
From what I can gather it might be that the needle that is used to puncture the K-Cup might be dirty. You can take a paper clip and see if that will dislodge any grounds that might have built up. Otherwise I would check your water pump, as that might be causing the issue.
这个答案有帮助吗?
得分 1
2条评论:
i have cleaned needle as well ...still causing issue .... put water pump in vinegar still giving issue ...put a dfferent water pump from a different keurig on there ...still giving that issue so im wondering if it could be a solenoid ?
由完成的 分享
@norbie I would definitely try that next and see if that has an effect on the issue. Thankfully a replacement part doesn't seem to be insanely expensive if you want it brand new.
由完成的 分享
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 683
